- Andreas
An electromechanical SLR camera that won’t take a picture can’t be used for photography.
If it shows no signs of life at all—not even the electronic viewfinder displays are working—you can assume it’s a total loss, and you have two options:
The second option saves time and energy, but you’ll never know if the problem could have been fixed after all. Maybe even with very little effort.
Here, I’ll outline a third option: taking matters into your own hands.
An Nikon F3 worked on the MD-4 Motor Drive. But it could not be triggered at its own with the electronic shutter release. Anyway it but could be triggered with the mechanical reserve shutter release. The LCD did not show anything in the viewfinder.
Clearly a problem with the power supply.
The error can occur in a number of places, for example:
A troubleshooting guide from C & C Associates for electronic problems was once again helpful here, in this case for the Nikon F3.
The very first decision diagram under „Power Circuit Malfunctions“ led to the solution.
Since the operating voltage of ~3 volts could not be measured at test point TP-1 (one of the contacts of the connector for the Motor Drive MD-4 on the bottom of the camera) the guide lists the following possible causes:
After removing the base plate with the rubber seal cover, I saw that the positive contact of the battery compartment was not soldered to the circuit board.
This was quickly remedied with a soldering iron. The F3 can now be triggered with the shutter button, and the LCD works again.
At this point I also cleaned the rubber cover with isopropyl alcohol.
The seal around the motor drive coupler seems to have fallen apart on every F3 by now. I'm leaving it in place here, as it's still holding and offers some protection against dust and dirt.
Nikon F3 Repair Manual
A small brass bushing that centers the pin over the trigger contact is missing near the winding lever. But it works without it.
A simple repair that brought the F3 back to life
Conclusion
A cable that had lost contact rendered a Nikon F3—which otherwise works perfectly—inoperable. Fixing the problem required a screwdriver and a soldering iron.
The challenge is finding the fault. Here, experience helps, but the available technical documentation is even more valuable. And, more recently, AI—when used wisely—has also become a valuable tool.
The technical skills can be learned.
And the joy of getting something working again with your own hands motivates you to stick with it and keep learning
A word of caution
Please keep in mind that you’ll be using highly flammable solvents for service work, and their fumes are harmful to your health. Soldering also produces fumes that should not be inhaled. Dangerous high voltages can be present when handling electronics, especially in conjunction with electronic flash units and mains. Therefore, familiarize yourself with the safety regulations beforehand and ensure your safety. Depending on the activity, protective gear may be advisable.
All information is provided without guarantee. Any action you take upon the information in this report is strictly at your own risk.
This report describes my personal experience and approach; it does not constitute a professional or certified repair instruction. I am not liable for any property damage or personal injury resulting from actions taken based on the information provided in this report.
Acknowledgments
Without the work of Master Larry Lyells, in particular, we wouldn’t have the detailed technical information we need today for service/repair of electromechanical SLRs.
The SPT Journal and The Camera Craftsman, which he helped shape significantly as an author, and which contain all the necessary information and instructions are available for a fee through Learn Camera Repair.
We owe our access to them to Eugene Pate, the founder of Learn Camera Repair.
- Either find a repair shop that can fix the camera,
- or give up on it.
- in the battery compartment,
- on the battery contacts on the circuit board,
- on the shutter release switch,
- on its contact,
- or there is a defect in one of the ICs.
battery terminals, solder connection to flex (red wire), or battery box ground to flex (black wire).
Conclusion
Acknowledgments
