- Chris
Have a problem occur with my printer this weekend and wondered if anyone else who has or has had the same make model etc and had suffered the same fault.
It's a Canon i9950 A3+ Printer (Picture below)
Problem is when it's turned on the power light comes on but the printer does nothing else! Even if you lift the lid to check the inks the print head doesn't move either!! It can't be turned off by the normal on/off button press, the buttons on the front panel do not respond at all (Not even pushing a piece of paper though if you press the paper advance button)
From the computer side of things the PC doesn't see the printer at all reporting that it's offline (although it is turned on and has power going to it)
I've done a few searches and have came up with very little.
Anyone suggest a solution??
This is the printer (with the light that stays on showing)
but then does nothing else I'm affraid :razz:
