woof woof
I like a nice Chianti
- Alan
I'm having problems correcting vignetting when using PS2022.
In CS5 this was simple, all I did as move the vignetting slider until the vignetting was corrected. With bad vignetting the slider needed to be moved far to the right and the numerical value of the correction would be 70% or more.
In PS2022 moving the slider to the far right creates white corners and the numerical value to get somewhere near where CS5 would be is something like 6 or 7. I've tried entering decimal point corrections like 6.5 but these don't work and only whole numbers seem to be permitted. With PS2022 whatever I do I can't get near the level of CS5 and the corners remain too dark or begin to be too light or I get variation from top to bottom and it just doesn't seem to be anywhere near as easy or good as CS5 and I'm finding CS5 much better for this basic adjustment which surprises and annoys me as PS2022 should be better, I hope.
Has anyone else seen this or know a quick way around it?
Going into "Calibration" in PS2022 and changing the version to an earlier one doesn't seem to work and CS5 still seems much better for this correction but I hope there's a way to get the newer version to better correct vignetting... Googling this hasn't helped so help needed from knowledgeable forumers
