Can you boot to safe mode and do a system restore to the point before it stopped working.
What was I saying about Registry Cleaners...
What Operating System do you have?
When you press F8, do you see Startup Repair/Repair your computer as an option?
If not, you will need a Vista Installation Disc to fix this, do you have one available?
Regarding the disc, we sent our computer to have a fan fitted and went to collect it and they told us that they had broken the motherboard, and had to fix it and gave him a new motherboard and loaded Vista 64 bit on there.
they loaded a new operating system for a broken motherboard? did you get any of the media or licence key?
Nope :bang:
first off thats illegal.
you could use that to your advantage and tell them to fix it AND supply you with correct media and licence or youll report them for distributing unlicenced software.
That would be extremely tempting right now but it has shut down
Do you see Last Known Good Configuration in the option of F8 things?
I would definitely have a moan at whoever repaired it.
That wouldn't be necessary, all you would need is a linux distro. Ubuntu Live CD would work fine for accessing files and backing them up.
ChrisH said:Squizza
I have a genuine copy of Vista Ultimate 64bit knocking about that I dont use, if I can find it I'll send it to you.
just pm me your address *** I cant find it.
ChrisH said:Errr Neil it's a genuine copy with COA.
If it never got registered, it won't have been seen by M$....Sarah can register it if she wants it never got registered, probably have to ring microsnot to activate it because it will be on a different computer than it was first bought for. Microsnot might wriggle but they will activate it.
Ahh.. I thought you meant activating. Having said that, I have a copy of Win 7 OEM (I am the OEM!) I moved between PCs and it activated on both of them fine (only one running before anyone says anythingNot true.
Registeration and activation with Microsoft are two totaly seperate things.
It's been activated on my computer so more than likely Sarah will have to activate it by phone.
Registeration is a totaly seperate thing.
Ahh.. I thought you meant activating. Having said that, I have a copy of Win 7 OEM (I am the OEM!) I moved between PCs and it activated on both of them fine (only one running before anyone says anything).
I looked into this when I upgraded. Basically, the OEM is responsible for supporting the OS on the hardware so defines what is an acceptable change to make. As I'm the OEM, I can make as many changes to the hardware as I seem fitit does seem to depend on what day of the week it is, what the weather is like and what colour underware you have on as to whether the activation goes through on transferred OEM copies to be honest..
Please please can someone advise.
My dad has updated to Advanced Windows Cleaner 4, and since the computer will not boot up properly, and keeps restarting itself.
What to do?!
Thank you in advance.
Sarah
