viewfinder: FX lens on an DX body
Allan
I have a d90 with a 24-70 f2.8 lens. Over the past few weeks i've noticed that i'm chopping off the top of heads etc. The other night when i set up the hilite i made a point of leaving a decent space around portrait shots, but once uploaded its clear that the top of heads are missing.
i always thought viewfinders normally show LESS than the actual image ? does an FX lens on a DX body cause this problem?
Al
I thought the same at one point but it is the easiest thing to check. Just take a shot so that you get the top of a door exactly on the edge of the lens and see what you get......
just tried it with the telly , as its not far off a perfect fit. it is pretty much bang on, even liveview. oh well, my concious effort to frame better wasn't that conscious after all!
cheers, al :shrug::wave:
Yup which means the pentaprism that sends the light to the viewfinder is out of alignment.
Back to the workshop...
Sorry, but if what i frame through the viewfinder is pretty much exactly the same as the recorded image, then i still have problem?
The D90's viewfinder has 96% coverage, which suggests to me that if you frame a door frame tightly, you should have a little extra room around it in the actual exposure :thinking:. It certainly shouldn't be cutting of parts of the image though :shrug:.
