- Jonathan
Yeah - tried those. They are pretty nice. Limited power though
As Bob Dylan famously sang, The Times They Are A-Changin
In a few days from now there will be a flash trigger set available that will allow Nikon DSLR cameras to be used at a genuine 1/8000th sec - and no, this is not Hypersynch, HSS, tail end hack or anything else, it simply allows any Nikon DSLR camera to be used with any flash at any shutter speed.
This will produce effective flash durations of 1/8000th sec with the Safari Li-on, and come to that with any flash. And you don't need to understand how t.1 and t.5 flash durations are measured, you'll get exactly the same result with flash, in terms of action stopping potential, as you'll get with daylight at the same shutter speed.
The first batch will be for Nikon only. They will also be available for Canon soon.
I don't think you have And they produce full powerYeah - tried those. They are pretty nice. Limited power though
No, totally different technology and no loss of powerSo are they similar to Hyper sync on a speedlite, fast shutter speed but naff all power coming from the flash?
It won't be secret for much longerIs it secret squirrel or can you tell us who, what, when, where?
They use all the power produced by the flash and captured by the shutter.
Obviously, if the flash duration is say 1/1000th and you set the shutter to 1/2000th then you will only use half of the power, so will need to open up by a stop, this becomes 2 stops at 1/4000th and 3 stops at 1/8000th - but if necessary you can increase the ISO to compensate.
Obviously, if the flash duration is say 1/1000th and you set the shutter to 1/2000th then you will only use half of the power, so will need to open up by a stop, this becomes 2 stops at 1/4000th and 3 stops at 1/8000th - but if necessary you can increase the ISO to compensate. The dramatic reduction in the amount of ambient light entering the camera at very fast shutter speeds allows day to be turned into night if required, so increasing the ISO is the perfect solution - unlike existing technology, where ND filters often have to be used in bright lighting conditions, to effectively reduce the ISO
It is correct, and it will be a massive game changer. There will no longer be any point in paying a lot of money for short flash durations, either in the studio or outdoors.If this is correct, that's a pretty big game changer.
Nice shot Jonathan, but that was taken at very close distance with extremely low power. What I'm talking about will light a motocross bike from several metres away1/8,000s in sunlight with flash.
George, I've tried to provide accurate answers.Garry - I've bought into your current lighting system and therefore support you, but you really are s*** at responding to people on this forum sometimes. About time you stepped off your moral high ground and just posted pictures with exif you'd taken which prove your point instead of claiming things while not actually backing up...
Well yes, the amount of flash power actually used is directly related to the combination of shutter speed and flash duration. So far my tests are limited to the D200, D300, D700 and D3. On my own cameras, increasing the ISO a stop or 2 to compensate for the difference between shutter speed and flash duration really is a non-problem.From a technical standpoint, I'm confused as to how it could possibly work. Certainly at anything higher than very minimum flash powers on all flashes other than the highest end profoto packs, the duration is wayyy longer than 1/8000th of a second, so whatever happens you'd not be getting the full flash.
What will the ramifications of this be for the current market?
Ah ok, so the new trigger is more about getting shorter durations as opposed to better ability to over power the sun?
check out goldenshell to see what it is
Interesting!
So I guess this is the Safari Li-on?
http://www.ebay.co.uk/itm/Jinbei-Di...931?pt=LH_DefaultDomain_0&hash=item20be3e9913
Anyone know what the import duty would be??
No, it's the Jinbei Discovery, on which the Safari Li-on is based. Apart from POAH, just about everyone knows that. See here
OK, so you want proof...
First, my apologies to George, this is my old, mud splattered off roader, I haven't got a pretty car to photograph.
Second, I used a Safari Li-on and placed it 20' from the car, to demonstrate that it has enough power. I didn't measure the distance, just paced it out but it will be about right..................................
The first shot is a control shot, no flash, the camera decided that an acceptable exposure at 1/8000th was f/2.8Garry, I'm just trying to get my head around this, but I just don't understand your images.
I've been up since 3am this morning so I appreciate I may not be functioning as normal but, If no.1 is shot at 1/8000th at f2.8
Then in No.2, I don't understand how the background looks roughly the same exposure when you've dropped your shutter speed by 5 stops and your aperture by only 2 1/2 stops?
And in the final shot at 1/8000th again but at f4.0 surely that means the background is only 1 stop under from your base exposure of f2.8 at 1/8000th, not 3 stops?
Richard, with respect you should keep an open mind until the Canon version is available, as I'm kind of relying on you to be the first beta tester (I don't know anyone else who both uses Canon and who can be relied upon to test thoroughly and impartially) If you then find that you're right, you can announce it on this forum.Garry, the kind of miracle machine you're appear to be suggesting is not possible. That would require a completely new design of camera shutter, and no trigger can change that.
I would respectfully suggest this is some variation of the tail-sync hack. Certainly looks like it from your middle fan shot (clearly brighter at the bottom).
treeman said:Still none the wiser buddy :shrug:
<snip>
Ah, I didn't know that you had a proper camera, in that case I may be able to let you have my set for the Nikon earlier, then you can see for yourself whether it really is a game changer or whether it's just another bodge.BTW, I also have a Nikon D700 sitting here
IGBT technology is pretty useful, but it has inherent bugs that limit the maximum rated power, and which then effectively cut that power in half, so it's not quite there yet - or at least, not on the ones that are currently on sale.But until then, the most likely prospect seems to lie with IGBT flash technology, not any form of trigger.
Will this trigger be available for Sony or work with a hot-shoe adaptor, or is there more to it than that?
Garry Edwards said:Sorry, but no. It won't work with a hotshoe adapter. It could probably be done as a specific trigger for your camera, but the development cost involved, for a customer base that is potentially pretty small, would make it impossible.
Because of these costs, I very much doubt whether it will ever be available for anything other than Canon or Nikon.
Sorry to say Garry that I'm unconvinced of anything so far! The problem is the focal plane shutter. Your IGBT tests at lower power settings should nail it.
