Excuse me if im not getting your point BTW.
Except the image algorithm has been applied. ..which is what does the damage it seems... at leasts that where we got to I think.
I see the problem as us looking to hard at kind of early technology and comparing it to the god of film. I see it as being down to the art of the hardware and software engineers that goes much of the way in the final consistency of images produced, errors are corrected, magic is performed and the end result is a compromise for best overall effect ..as technology gets better, the bar is raised again.
I think this thread is simpler than that and if one has a better understanding of the possible causes of the issue one has a better chance, potentially, of doing something to avoid or reduce it. The thread has nothing to do with film or artistry or technical advancement, as far as I can see. The nub of the question is....
"Why does a shot taken at f/8 in good light look cleaner than the same shot taken at f/1.4 in lighting 5 stops dimmer with no adjustment to shutter speed or ISO?"
On the face of it you'd think you would be capturing the same number of photons and basically have the same amount of noise. But, in the thread we have put forward some ideas which may or may not have merit, but seem to be plausible. They are, in no particular order....
1. When you shoot with shallow DOF (wide apertures) noise can appear in areas where previously it was not apparent. This includes smooth, featureless OOF areas and also transitions at high contrast edges.
2. If light levels do vary by 5 stops it is possible/probable that the colour temperature becomes skewed and adjusting white balance to compensate may well increase noise in the channel which was starved of light. Tungsten light (very orangey red) will cause blue channel noise. Shaded daylight (very blue) will cause red channel noise.
3. Fast apertures may gather more light than slow apertures, but the efficiency of light gathering reduces the wider/faster you go. This means that if you maintain the exposure level by the numbers alone you may end up underexposing more as you open up the aperture
4. With very fast lenses and wide apertures light falloff in the corners is likely to be worse than when stopping down. This is closely related to point 3, but emphasised at the edges and corners. If you choose to correct that in software then you could well find yourself needing a 2 stop push in the corners, which inevitably will have a negative impact on noise in those areas.
As for comparing files, be they raw or JPEG, one way or another they will have been processed by software to turn them into a visible and usable image. If you've ever seen a raw file in its native state you'll see it's a flat looking file with a heavy green tint. Here's an unprocessed raw image, which was shot with a good exposure and decent white balance, but the bare raw file looks very odd indeed. In this image the house is painted white and the sky in the background is featureless grey cloud. The green tint is no surprise since the Bayer array has twice as many green pixels as red and blue.
It needs to be software manipulated to be useful as a picture. The question we can't really answer is whether there are any "under the covers" adjustments made by the rendering software before we get our hands on it. For example, if you enable HTP (Canon feature) your raw file will be underexposed by 1 stop courtesy of a secretly reduced ISO value. DPP will see that HTP was enabled and apply a special tone curve to adjust how the image is displayed. I don't know how other software tackles the issue. It was the case, and possibly still is, that Lightroom would blindly double all the raw data values throughout the tonal range, just emulating a brighter exposure in the first place. You also have picture styles and camera profiles to consider. Whichever way you look at it the files have to be processed and do we really know if there are any little secret tweaks going on? I don't. I have to work on the assumption that the playing field is level, but who knows?
So, at the end of all that, nothing to do with film, nothing to do with art, nothing to do with technology advances, just some ideas to be considered when trying to reduce noise in these low level lighting scenarios. Is fast glass always the best answer (where noise is concerned) or could we get cleaner files by stopping down a bit and reducing shutter speed, if that option is viable? Is natural light always the best answer or would we be better off chucking some flash into the mix? Do we shoot tight and fix the vignette, or shoot loose and crop it off? Or do we say "Screw the noise, I'm an artist." and I'll shoot however I damn well please?
Better to know about these things and weigh up the options than to know nothing at all.
p.s. There's always Neat Image
