- Toby
This isn’t true actually, if you want to learn photography ‘properly’ then the principles are the same no matter what the gear. Also, high end gear tends to be more complex and therefore harder to learn. Also correct focus is far more critical with full frame cameras versus APS-C, m4/3 and the other smaller sensor cameras.The reason ive set a budget is not because i can not afford it but everything is easier if you chuck thousands at it and thats not a challenge...
People seem to think that buying all the best gear will turn them into great photographers, ......,it won’t.
