Kodiak Qc
Suspended / Banned
- French Canadian living in Europe since 1989!
My coasters are stainless steel #fml
Fold some paper up.
managed to find two similar items with a grippy surface, another shot in the freezer and tried the method as above. I failed again. Im starting to think it is glued on. but who would do such a thing?
Don’t need freezer, both parts will expand and contract at the same time. You press and twist. You need the towel to the table for the grip. You need to press down hard.
Good plan, but what if I ever need to get the end of the lens off? Can’t see that I would but still.....Get some loctite and put a couple of dots on the lens thread, screw both back in and leave overnight. Use rubber gloves to unscrew the filter next day, the lens ring should remain in place. Superglue can be used instead of loctite in emergencies.
You need two of these - choose your size.
Using your hands causes the filter to distort ever so slightly and that makes it reluctant to move. You need to apply even pressure all the way round the filter.
Put one on the filter and the other on the (supposedly) non moveable barrel, twist in opposite directions, voila.
https://www.jackthehat.co.uk/filter-accessories-c-44.html
What I have is better than both of these:
New plan, get a spar part of the end of the lens and put it on. Throw the filter in the bin.
£60!
It would still come off with a proper lens spanner, loctite/threadlock doesn't set rock hard.Good plan, but what if I ever need to get the end of the lens off? Can’t see that I would but still.....
Put in freezer for 20mins, boil kettle, pour hot water into a bowl, remove filter from freezer, put the female thread part (the lens part, judging by your description of the situation) into the hot water, but only up to the uv filter thread, just for a few seconds. This may help to loosen it.
I'm not too sure if @gremlin16 is that worried about the uv filter.Or cause it to crack due to uneven thermal expansion if the part the filter is attached to is made of hard plastic/polycarbonate?
No, the filter ring will be made of metal, it's the end of the camera lens that might be made of plastic/polycarbonate, and I think he might want that bit!I'm not too sure if @gremlin16 is that worried about the uv filter.
OK.................Nothing seems to have worked..................So stage two, smash the bugger, dent the ring and pull it off................job done
Try the hot water in a bowl, it will work
Did you try the rubber bands?
I wouldn’t dent the ring! If you oval the filter ring you will snap the other ring !
Just my 2 pennith
It didn't, but thanksPut in freezer for 20mins, boil kettle, pour hot water into a bowl, remove filter from freezer, put the female thread part (the lens part, judging by your description of the situation) into the hot water, but only up to the uv filter thread, just for a few seconds. This may help to loosen it.
Send it to me and I will get it apart.
have you access to anything similar to a sheet of thickish rubber? I like the ideas suggested of pushing down on something to get grip, and elastic bands. A sheet of rubber would increase the grip further. So it’d be table->rubber->filter&lens end->rubber->hand! Push down and turn anti-clockwise.
