- Kev
Hi
Just bought a Sekonic L308-S light meter and am trying to learn how to use it. I have seen a few youtube video's and have had a quick read through the manual but for some reason cannot get the same reading each time.
I am using a YN565ex on a light stand 45 degree from the object, the flash is triggered using a YN622n on the flash and a 622n tx on the camera. I am using the test button on the TX to trigger the flash to take a meter reading. The meter is in the correct non corded flash mode.
As per the two pic below, one is showing F8 and another F1.3, so what am I doing wrong to get these incorrect readings. Also not the one at F8.0 look a bit under exposed.
Thank you
Kev
Thank you
Kev
