105km and 1300m of climbing from Wimbledon to Camber Sands. Now broken but happy!
Excellent - nice metric century. I'd sort of promised myself I'd do a proper century again before I hit my half century but as its my birthday tomorrow and I'm posting this from the pub's beer garden it's not looking promising...
Just bought a road bike, and I must confess... some lycra too
Wifey & kids think I look stupid
Only done two short rides so far and my arse is killing - but... LOVING IT
Dave
Dave
Bit of a long shot but has anyone got any experience with Wiliners road bikes?
I've been casually looking for a cheapish road bike and the izoard veloce looks kind of nice.
Just after a bit of back ground before I book a test on one.
I love Campag kit, but TBH It's only recently i've got back under the max. recommended rider weight limit for their kit... hence all the Shimano stuff...
Fork, tyre, front brake and truing the front wheel as well as all the labour. The 2013 version of the bike is £600 so it could have been worse!
What happened????
Out of nowhere, dressed up and went out on bike today. Went along thames path.
Have to say that it wasnt road bike friendly all the way...
I think i will get up around 7am tomorrow, and cycle to london bridge
Guy turned across road right into petrol station, totally ignoring the fact that I was on the other side of the road. I got rid of as much speed as possible but still hit his passenger door.
Agreed on the Thames path, it's not good for road bikes at all. Mind you most of the national cycle routes would seem not to be. I was on ncn 2 and it was just daft in places, way to lumpy!
leaning more to a push tuned fox van rc now over a rockshox monarch rc3 plus
after my last rides my gears need adjusting...road bikes in London are a nightmare...too many bumps and potholes ;(
few days ago, while pumping fron tire, valve broke..so will need to change it soon and believe you me, I am carp at changing tubes and will swear like a crazy muppet
and one more...how often do you use grease on chain and sprockets ?and what kind of grease ?
is dry lube any good ?
What he said.hardtail (with lockout fork option) with slicks is what you want
GT85 after every ride.
for the roadbike, the cassette gets removed and cleaned/degreased once a month (around every 800-1000 miles), the freehub cleaned then wiped over with a little grease just to save rust/seizing. No lube on the actual cassette teeth - it'll pick up enough from the chain. At same time, chain is removed, degreased, cleaned, chainrings cleaned, and chain re-fitted (use one of those "missing link" things rather than riveting/breaking.) Winter, I use finish line wet lube, but from around may-sept I'll be on the dry-lube - recently I've ben quite happy with the Finish Line Ceramic Wax Lube - ideally applied after a ride, so it has chance to "set up" before getting exposed to road dust the following day.
I also try to remember to run the chain-checker over the bike before a ride, and always make sure it gets swapped out at +0.7 (ie while it's still not damaging the cassette or chainrings) - chains are (relatively) cheap - Cassettes less so, Chainrings - not at all.
hardtail (with lockout fork option) - what is this ??
I do have gt85 somewhere ...will spray it on from now on
some tyres are just a pain to fit/remove. my schwables gave me blisters
really?? personally id have stuck to an air shock on that.
cheaper to buy and run - plus coils have better small bump reaction. no worried about air leaking either. it's 5.5 inch travel too
cheaper? yeah like a consumer camera is cheaper than a prosumer? service intervals are the same on fox coil and air shocks and TFT service fees are the same so shouldnt be any more expensive to run.
thats why i said get that push tuned RP23 from TFT, sorts out small bump performance. plus theyre lighter, more configurable (you have to change the spring on a coil). airs shouldnt leak air, my old RP2 certainly hasnt lost any. indeed fox say the sag can pretty much be set and forget.
not sure what you mean by its 5.5" travel though.. any shock can be any travel pretty much, its the frame linkages and the shock size that make up the travel.
but yeah coil vs air is a bit of a canon vs nikon argument..
Getting back into cycling and looking for a new bike. I mainly stay on cycle paths with Tarmac or compact gravel, was thinking of a hybrid maybe? What would I get for about £1k or is it worth going more?
I recently got a Trek 8.4 DS, which I love. It was about £650, 27 speed, 63mm travel front fork with lockout, runs 700c wheels with hydraulic discs, overall a nice ride
The top range 8.6 model is closer to £1,000 and has a slightly fancier frame and a few other features!
Dunwich Dynamo tomorrow, yay!
