- Peter
I got it from ebay for macros.
It arrived in a fairly good looking box (will upload photos of the box and the product itself later).
Its contents were seated in a pretty stiff plastic and I accidentally opened the part that goes into the camera hot-shoe. I managed to put it back together, though.
What was in the package:
- the led ring
- the 'command unit' that fits into the camera hot-shoe (also a power source for the ring)
- ac adapter
- 2 batteries
- screw on adapters (49, 52, 55, 58, 62, 67mm ones)
Ones mounts the command unit onto the camera, screws the adapter on the front element of the lens like a filter and slides the led ring onto the adapter (or the adapter into the ring).
There's a cable on the ring that has to be connected to the command unit. It's long enough for my Sigma 70-300mm (also used for the photos below) at 70mm with three extension tubes (one set) used.
The ring can rotate on the adapter if the front element of your lens rotates as it focuses, which can be an advantage and should be fine unless you need to use only one of the sides of the ring.
Please excuse the poor backgrounds in photos of the product.
It arrived in a nice, but somewhat battered box:
The plastic in was seated in was so hard that I managed to open the command unit. It didn't hold together too well afterwards, so I put a rubber band on it and it's enough to keep it together (it's very light).
Close-up shots of the command unit:
The ring itself:
Back side of the ring:
You can choose to light up the whole right or a half of it:
- the led ring
- ac adapter
- 2 batteries
The ring itself:
