https://www.ubitricity.co.uk/b2b-local-authorities/
The current leading lamppost solution does not say whether it does or doesn't require replacement of existing cable. But there's already so many already installed and I've personally not seen newly laid road near the lampposts.
Flats car parks can get chargers built-in. The new block of flats next to North Circular bottleneck point (end of Bowes Road) has an EV charger at every bay. The houses behind those flat has no garden (booo), but has solar panels on the roof and EV charger pre-installed (yay).
But you would be changing the battery again next time it needs a recharge so you wouldn't be saddled with a poor battery devaluing your vehicle. It would be very easy to monitor the battery capacity and as they get too low they can be recycled for storage purposes.
Personally I relate it to buying range. I go into a petrol station, buy petrol and leave. I don't really see the battery as my problem. I'd like it to be a rental thing, I go in, battery gets swapped out, same thing at the next stop. Saves a huge amount of infrastructure being installed at a huge carbon cost.
So, to answer your question, provided the battery had the required capacity, I don't really care about the condition of it, that's the worry of the battery owner. Up to them to make sure it's fit for purpose.
So in your view, it is better to have battery-swap facilities instead of re-charging? Every 200-300 miles you are required to visit a battery-swap station?
Or, battery swap only happens for long distance drive. Then, if someone only travels long distance every 2 blue moons, other times they drive their car close to its range limit. Each and every battery swap becomes a gamble, whether this newly swapped in battery will be able to sustain the same driving style.
Battery rental has proven to be pointless and unpopular by early Leaf and Zoe. Battery swap had been tested by EV manufacturers and had not taken off. En-route charging time is ever decreasing, with infrastructure cost covered by on-site batteries also getting paid to provide grid services. And there are so many different shapes and sizes of cars. So it's unlikely we'll ever see battery swap stations ever........
Ev's really are the preserve of well-off people with dual driveways and enough money to upfront the cost of ownership due the their higher initial price.
ICE cars have given personal transport to the masses Ev's are going to reverse that, but why would that worry some people.
I personally see the opposite
when EV's begin to trickle down in the used market and budget segment. AEB and ACC used to be a high-end car option, now it's in almost every segment.
The
current stumbling blocks for the less well-off are: (as been pointed out)
- EV purchase price, due to lack of choices of EV, many manufacturer did not make their EV available in volume here (Focus EV, Fiat 500e, etc)
- Driveway requirement, due to lack of investment on public charging. Start-ups does not have the resource to do these install, need the car companies and local government support. See Ubitricity install coverage in a well supported borough, see Milton Keynes.
Then, there's possibility of cheaper AI driven taxi. Something my parents, who are approaching 70, are looking forward to.
